Lachiepower0402
- Aug 14, 2014
- 2
- 29
Hi everyone,
First of all I am knew to these forums, also I am amateur at small engines and I just do simple repairs for a hobby, but this problem got me stuck.
I have a Briggs and Stratton engine attached to a Victa lawnmower with the following specs:
Model = 92908
Type = 5175 01
Code = 82072308
Horsepower = 3.5
CC = 148CC
So my problem is that when I started the mower on the throttle setting of start, it run very slowly at about 2rev per second and increases after a while after I slow the throttle down and if I try and increase it to near full throttle it just dies and when I try and start it again it won't start, it just starts for 1 rev and dies. I have to leave it for about an hour or so before it will start again and do the same thing
Also to start it I have to take the air filter and air filter housing off otherwise it won't start, I have cleaned the air filter and oiled it.
It has been sitting in one of my mate's shed for who know's long after it wouldn't start and he decided to give it to me to fix, first of all I drained the old oil and put new oil in and the fuel that was in it before had evaporated so I just about half a litre in and it started doing what it is doing now.
What should I do, is their something I can adjust like the idle speed and how? Should I clean the carb?
Thank you in advance
Model = 92908
Type = 5175 01
Code = 82072308
Horsepower = 3.5
CC = 148CC
