Problem with my 2003 John Deere L130 (Will not start just a click)
Rondo
  • / Problem with my 2003 John Deere L130 (Will not start just a click)
Hello everyone,
I have a 2003 L130 with 175hrs with the Kohler Command Engine.
I was mowing my very long grass today (just over an acre) and I was nearing completion when my mower started to die on me.
Almost asking like it was running out of gas. So I shut her down not long after noticing this stalling. I went to fill it up and I noticed some gas still in the tank.
So filled it up and when I turned the ignition all I hear was a click under the hood and nothing.
I tried this a few more times and still just a single click and nothing more, whisper quite.
My battery reads good, oil is fine also. Im at a loss as to what to trouble shoot now? Any input would be greatly appreciated!
Thank you
Run a jumper from the battery - to a good ground near the starter motor, the oil drain plug is good if you have a std plug.
Engine cranks & starts = bad ground connection
Run another one from the battery + to the + terminal on the starter motor
You should get a big fat spark so be ready for it
Starter cranks & engine runs = bad power connection
Rondo
Thanks for your response! I decided to mess around with my pull switch that engages my mower blades. It was pushed down that is correct for starting. However since the mower died before I pushed the disengage it never registered. My mower did run out of gas since I was not on level ground and it was low. So I was able to turn the key to accessory, engage the blades and then disengage the blades and then start it back up. I feel dumb... but hey at least I don't need to order any parts!
Thanks Bertsmobile1 for trying to help me.
You ain't the first that has done that and won't be the last either.
Glad to hear you are back on the grass.
