PRIMER BULB
kwhittler
When I push in primer bulb the engine begins immediately. After running about five minutes, the engine stops. I will go to prome it again and the bulb has sucked in. The air filter is clean and the lawn mower is only a year old.
The air vent into the carb bowl is blocked.
Can't tellyou how to fix it because I don't know what mower & carb you have, Pity.
