Homeby5
- May 21, 2020
- Threads
- 1
- 1
I use my Stihl blower everyday. It ran perfect until I changed the primer bulb. As soon as I changed the bulb....my blower will start but not continue to run. I know the electircal is good because it will run when I spray starting fluid down the throat. It has to be something I did when changing the bulb because as I said....it ran perfectly. I have performed/cleaned checked the following:
Disassembled and cleaned the carb
Fuel filter
Spark arrestor
Check both fuel lines (return and supply) for clogs
Question: When you disassemble the carb and blow through the fuel return nipple...the one that goes to the plastic housing that the bulb mounts to.....it has a strong resistance. It also has a strong resistance to vacuum. Is this OK? The fuel supply offers no resistance.
Thanks guys
Fuel filter
Spark arrestor
Thanks guys
