You can take cheap E10 and use water to remove the ethanol. Kinda a PITA but you get better gas.Y'all are lucky. It's illegal for gas stations to sell E-0 here. Have to go to a marina or racetrack and pay $5+.
Yup, if your station uses a "common" hose for all the blends. Luckily our stations have a separate hose for the 91/non-ethanol Octane. Today's price for Premium is $1.70....$1.35 for 87 octane....and the prices may drop even further in coming weeks. Some places in Missouri are at $1/gal for 87 regular....that's about the Only good financial news lately.
When ever you use the nonethanol fuel, please remember to do this. Before pumping any fuel into your gas can puta gallon or two into your car. Why? With today’s one hose pumps you have no idea of what the person before you used. You may end up with a half can of ethanol fuel in your can, because that is what is left in the line back to the transfer point. Your car won’t know the difference, but your small engine will.
We all recognize the advantages of E0 versus E10 but I've never heard of E0 improving carb. performance. What is it about non-ethanol gas that would lead to carbonator cleanout after a month's use? The same applies to premium versus regular; higher octane usually doesn't translate to performance improvement by itself.
I don't know about a "month" but the issue is that Ethanol is harmful to the rubbers found in carburetors and fuel systems. Have you ever wondered why not all vehicles are capable of running E85? It's not just the computer that has to be capable of adjusting for the increased octane, but he fuel system components in E85 are completely different (materials) to handle the added ethanol.
So, while virtually all engines intended for regular unleaded, containing some small amount of ethanol, should be fine, it does not mean that the machine WONT have some small adverse effect over time. This is why most engine manuals for small equipment specifically direct consumers to use a fuel additive that combats the harmful effects of ethanol.
