suzukizone
First time posting. I mounted a 212cc, 6.5HP Predator engine on a vintage Mighty Mac Shredder/Composter. Original engine was likely in the 3 HP range, I believe.
The engine starts up fine from cold, sits and runs at least 5 min OK but when I engage the belt drive, even before putting in compost, the engine runs for 1/2 min to 3 or 4 min but then shuts down sounding exactly as if running out of fuel but bowl is full. Then won't start until the engine sits for 10-15 min. Fuel flow from tank more than sufficient to keep up with needs. Tank full, have pulled carb and cleaned thoroughly several times. The float level is not adjustable. Fuel is clean & fresh. No direct access to the vent in the cap tho have tried to be sure it's open with comp air and carb clean spray as best I could. (Have same result if I run with the fuel cap completely removed.) Spark plug looks OK, slightly dark but engine never ran long enough to heat up and burn clean. Not so dark as to fire bad tho. Good wide spark although more to the yellowish color than bright blue/white.
When the engine does run, it sounds good and strong and when cold it starts up easily with a light pull.
Any ideas are appreciated or if I am in the wrong forum please advise if there is a more suitable forum.
Thank you so much.
DH
Thank you so much.
DH
