kerryswinney
I have a 2005 Walker Mower with 18 hp Kohler Command motor and a 48" deck. I have 560 hrs on it. My issue is this. When I start mowing for the first hour it is perfect. But for some reason around that hour or 2 it will do something wierd. It will just simply die down while the blades are engaged. When i disengage the blades the motor runs fine. But when i engage the blades it will die back down and sputter. I have replaced the fule filter made sure every thing was at approperate levels (oil). I have also made sure that the air filter is blown out. But for some reason it does this. Does anyone have any idea how to fix or what the problem is. I have also put fuel injector cleanear in it as well. That seems to work but i am affraid that it is something else.
Thanks
Thanks
