Poulan pro riding mower lever loose and want go in gear
Fish
  • / Poulan pro riding mower lever loose and want go in gear
Sometimes a pic helps, I have taken a cheap wrench before to the grinder to make it slender.link.JPG
To those who have them, tappet wrenches work great for these jobs. They also work great for removing fuel solenoids.
cth
Unless it was done by an owner the nuts are never welded on
If you look closely near the rubber seal you will see 2 flats or a very thin hex these are there for a spanner .
The only problem is a lot of them are very thin and require either a stamped or ground down spanner to fit .
I purchased this new in 2019. Attached is picture of the replacement (with the seal removed). There is no hex in it. Same thing with the broken one. Even if there were, there is no way to get it into part 134 because the nut cannot be removed.
[ATTACHREUSE]
