Poulan Pro PP 22VA48
Freedom
I have problems with this part. I do not know the name in english. i enclose a foto of the part and the data of my mower.
I would like to know:
name and code number of the part
estimated price
can I buy only the broken part?
Thanks!! Many thanks for your help!
F
PB22VA48 with RS800P transaxle Driver Kit superseded name wise to anti-debris kit
GTI-GT79452 / Husqvarna 589668301. Source the GTI part if you can.
Freedom
Thanks for you quick reply ! , I do not understand " source the GTI part.." you mean to buy GTI and not Husqvarna?
Well would you rather pay up to $118 retail for the GTI part or up to $150 for the Husqvarna part even when it is the same part? And some vendors will be even higher. This is why I have several different sources for the parts.
Basically General Transmissions Inc is the manufacture of the transaxle.
Freedom
ok, now I understand . Thanks!
Hy Startech
I found a place to buy the part , thanks
could you give me the code for the drive belt ? (the blade belt code is 197242)
thanks!
F
If you are looking the Motion drive belt from the engine to transaxle then it is 197253 > 532197253 > 592855001 (1/2 x 100.50). There is also a couple V idlers that probably needs replacing. 532194326 and 532415680. The transaxle belt is GT37401 (Husqvarna 587086101).
> indicates superseding numbers.
Freedom
I change the pulley and the transmission belt (197253) and works very good.
great help!
F
