Poulan Pro PP 22VA48
Freedom
I have problems with this part. I do not know the name in english. i enclose a foto of the part and the data of my mower.
I would like to know:
name and code number of the part
estimated price
can I buy only the broken part?
Thanks!! Many thanks for your help!
F
PB22VA48 with RS800P transaxle Driver Kit superseded name wise to anti-debris kit
GTI-GT79452 / Husqvarna 589668301. Source the GTI part if you can.
Thanks for you quick reply ! , I do not understand " source the GTI part.." you mean to buy GTI and not Husqvarna?
Well would you rather pay up to $118 retail for the GTI part or up to $150 for the Husqvarna part even when it is the same part? And some vendors will be even higher. This is why I have several different sources for the parts.
Basically General Transmissions Inc is the manufacture of the transaxle.
If you are looking the Motion drive belt from the engine to transaxle then it is 197253 > 532197253 > 592855001 (1/2 x 100.50). There is also a couple V idlers that probably needs replacing. 532194326 and 532415680. The transaxle belt is GT37401 (Husqvarna 587086101).
> indicates superseding numbers.
I change the pulley and the transmission belt (197253) and works very good.
great help!
F
