Poulan Pro 22HP48 / Lubrication points
Freedom
I have just bought a Poulan Pro 22hp48
My manual has not the greasing o lubrications point.
I found 2 on each front wheel and 1 in the upper part of each blade (do not know the english name)
4+3= 7
I would appreciate if someone could confirm or if there are more points to lubricate.
thanks !
F
The things that hold the blades go by either spindles or mandrels depending on manufacturer. Some riders with cast iron front axle have a grease fitting on the bottom center of the axle. Some people also lube the steering gears, but need to be careful because oil or grease can attract dust, and that can act as an abrasive. Some people recommend a dry type lube for those sometimes. Also a drop of lube on the deck mounts and pivots may reduce wear in those areas.
Look closely at the mower.
Everywhere that 2 pieces of metal touch each other, holes with rods trough them , springs in holes , the arm that holds the belts tight, the steering gear and the rod that goes up to the steering wheel, all of these places need some sort of dry lubricant.
I use spray on lithium grease and to give an example I get 3 to 4 mowers out of a can
