RYANS'
- Jun 15, 2022
- 76
I have a ride on mower, poulan pro. The manual clutch is engaging, although it is old, and makes a rough sound when I pull on the belt. My issue is when I get to some longer grass the blades stop spinning. When I disengage and re-engage the clutch on smooth ground the blades take a bit to start spinning again. Like the belt is loose, although I have put four springs on the tensioner arm to keep it tight. Ai said it was the wrong belt, but it is the right one. My dealer said sometimes the brackets get bent underneath, so I checked and swapped the mounting bracket with the opposite side, just in case they were bent towards the clutch assembly. Alas I still have the same issue. Any advice is good advice here, thanks.
