So, I have an update:
A bit of a back story first: 2 weeks ago, I used this mower for the first time and cut grass with it for a couple of hours. It ran Ok. Next morning, it was hydro locked. So, brought the mower home and ordered a carburetor for it.
While I waited for it to come in, I added fluid to the Foote/dana transaxle D6800 with 80w/90. Today, I installed the new carb, mower fired right up and ran well. However, when I put it in gear, there is zero movement (well, it did move maybe 4" once). I did not touch any belts or make any adjustments to them. All I did was remove the rubber plug from the transaxle and add fluid. The mower was cutting grass and driving fine when I shut it down 2 weeks ago. The drive belt seems to be loose to me, but not sure how much play it should have in it. There are not any strange noises coming from the transaxle or the mower. While the mower is running, I can change gears with the clutch out (not sure if that is an issue or not).
Where should I start? Belt or did I add too much fluid to the transaxle or something else entirely?
Thanks again for the help!
