Please, please help me get the trimmer started
mrstjp
Normally my husband does the mowing, but I want to surprise him while he is away this week. Everything is done but the trimming, but I can't figure out how to start the trimmer. I have searched all over for the manual and can't find it. It's a Poulon if that helps. And YES, it has fuel. Thank you for any help!!
Edited to say that when I pull the starter rope, it just sort of growls very quietly. That probably doesn't help, but just in case...
Edited again to say that it looks like it has both a choke lever and a bulb.
If you can help but don't want to post, please send a private message. Thanks!!
BKBrown
Are there any model and serial numbers on the trimmer ? -- this will help us try to help you.
Usually -- push the primer bulb about 3 times - put the choke on - pull the cord until it fires - put it on half choke - pull again until it fires -- turn choke off - (usually there will either be a start position that stays locked or you will need to hold the speed control full on while pulling)
If we get model and serial #, you or we can probably look up the manual online.
mrstjp
I think the model is PPB335. I don't know where the serial number might be located. Thanks for the help.
BKBrown
User Manuals | Poulan
See if this helps ! Pages 10 - 11 starting instructions.
STARTING A COLD ENGINE
NOTE:
DO NOT squeeze the throttle trigger
until the engine has started and runs.
1. Set unit on a flat surface.
2. Slowly press the primer bulb 6 times.
3. Move choke lever to the FULL CHOKE
position.
4. Pull starter rope handle sharply until engine
sounds as if it is trying to start, but do not
pull rope more than 6 times.
5. As soon as engine sounds as if it is trying to
start, move choke lever to HALF CHOKE
position.
6. Pull starter rope sharply until engine runs,
but no more than 6 pulls.
NOTE: If the engine
doesn’t start after 6 pulls (at the HALF
CHOKE position), move the choke lever to
the FULL CHOKE position and press the
primer bulb 6 times. Pull the starter rope 2
more times. Move the choke lever to the
HALF CHOKE position and pull the starter
rope until the engine runs, but no more than
6 pulls. If the engine still doesn’t start, it is
probably flooded. Proceed to STARTING A
FLOODED ENGINE.
7. Once the engine starts, allow it to run 10
seconds. Squeeze throttle trigger and allow
the unit to run for 30more seconds atRUN.
Release throttle trigger.
NOTE: If engine
dieswith the chokelever in theRUNposition,
move the choke lever to FULL
CHOKE then back to HALF CHOKE and
pull the rope until engine runs, but no
more than 6 pulls.
STARTING A WARM ENGINE
1. Move choke lever to the FULL CHOKE
position, then to the HALF CHOKE position
to set fast idle.
2. Pull starter rope sharply until engine runs,
3. Allow engine to run 15 seconds, then move
the choke lever to RUN.
NOTE:
If engine has not started, pull starter
rope 5more pulls. If engine still does not run, it
is probably flooded.
STARTING A FLOODED ENGINE
Flooded engines can be started by placing the
choke lever in the RUN position; then, pull the
rope to clear the engine of excess fuel. This
could require pulling the starter handle many
times depending on how badly the unit is
flooded. If the unit still doesn’t start, refer to
TROUBLESHOOTING TABLE or call
1-800-554-6723.
mrstjp
Thank you! Okay, I've gone through the steps and I think it might be flooded or something because it is just weakly growling, and I think I smell gas.
chance123
Has this machine been sitting a long time? I ask this because when these machines sit for a while, some of the gas that is mixed with oil will evaporate leaving mostly oil in the carb which doesn't flow well through those tiny jets. You never mentioned if it fired up at all. You said "growling" but did you see smoke out of the exhaust?
BKBrown
The last poster is right that the gas may be stale if it has been a while since it was used. Try it with fresh gas and without the choke for a few pulls - then without priming again follow the rest of the procedure. If you know how to remove the spark plug - you can take that out and let it dry - put it back and try again.
mrstjp
It probably hasn't been used in a month maybe??
I don't think I've seen smoke at all. When I pull the rope it either does (a) nothing, or (b) makes a very, very weak momentary sound. It's not a growl, but I don't know how else to describe it. It's not firing. I do think I smell gas, so it might be flooding out. I don't know if that helps diagnose the issue at all.
Thanks!!
mrstjp
One other question/concern. The instructions say to pull the starter rope no more than 6 pulls. Yesterday when I was trying to start it without the benefit of the instructions, I pulled the rope a LOT more than 6 times. Did I damage it somehow? :ashamed:
I wouldn't think so.
