Last week I replaced the ground cable, started the mower, and mowed my lawn. So, it seemed that it was the ground cable.
Today, I went to start it to mow again and nothing happened. No turning, no clicking, no nothing. I took out the ignitiins switch, messed with the connection, and got it to start. Phew! Not so fast! I hit the reverse pedal to back it out of the garage and the thing wouldn't budge. I then hit the forward pedal and it doesn't move. The whole time the engine is running and "squealing" when i depress the forward or reverse pedals. So, I go to the back and pull out the "nuetral lever" to see if I could push it. No luck. The rear wheels are locked up. What could this problem be?
