Please help me get this leaf blower started
so did you revers the fue lines to see if they are on wrong.
Yes no way lines are wrong. I am trying to include video. I hope it works. Driveway is too dark to see but you can hear what is going on. I have it on choke turn to run.... If I let go of the throttle you will hear it wanted to die. as soon I as I press throttle all the way again he blows leaves. At the end of the video I took my finger off throttle and it just dies. Thanks Keith
didnt work. Can you see it through this link on my facebook?
https://www.facebook.com/TaxOffices.of.KeithSabin/videos/1102137329967217/
was the blower trigger pulled to full?
yes I had it pressed all the way. sometime I would let up a little in the video but you could hear it wanted to stall. Towards the end of the video I had finger press a little on the trigger. But once I let it go it died.
Sounds like you need a carb adjustment.........To me ~!~!
