- Feb 19, 2020
- Threads
- 122
- 12,902
Wait a minute Bert don't give some idiot the idea of just grabbing the belt. There are some out there that would do it with the engine running.
Now in reference to Stens and Rotary OEM spec'd belts I have had problems with them with them being the wrong sizes too. I had huge argument with Stens last year after I brought four same OEM belts and all of them were 1.25" too long; just fell off the pulleys with deck engaged. As a Stens dealer I finally got them to pick up the belts so their techs could check them. A couple weeks later I get an email stating they were crediting my credit card for the belts and shipping charges. It hard to trust Stens if on the very first belt order they screw up.
Hammer actually all pulleys wear overtime. It just like the printers with stainless steel paper guides that I once repaired. I was having to replace the guides because the paper worn through them. Plus often the stamp pulleys actually flex open with belt tension too which why machine pulleys are better if they can be found in right specs.
But in general everything wears but getting that through to an user sometimes seems impossible.
