Also the design of the ring is different.
T Tyler47 Forum Newbie Joined Aug 20, 2021 Threads 1 Messages 9 Aug 20, 2021 / Piston Ring Replacement?? #11 Also the design of the ring is different.
H hlw49 Lawn Addict Joined Jul 11, 2021 Threads 50 Messages 1,766 Aug 20, 2021 / Piston Ring Replacement?? #12 If you are looking for the standard bore ring set the are 594437. The part no you posted is for .020 over size piston.
T Tyler47 Forum Newbie Joined Aug 20, 2021 Threads 1 Messages 9 Aug 20, 2021 / Piston Ring Replacement?? #13 hlw49 said: If you are looking for the standard bore ring set the are 594437. The part no you posted is for .020 over size piston. Click to expand... Thank you.
H hlw49 Lawn Addict Joined Jul 11, 2021 Threads 50 Messages 1,766 Aug 20, 2021 / Piston Ring Replacement?? #14 Tyler47 said: Thank you. Click to expand... Your welcome
N Need2learn Member Joined Apr 27, 2015 Threads 7 Messages 32 Aug 21, 2021 / Piston Ring Replacement?? #15 Hello I had that same engine with the same problem. One of the valve’s got stuck open on the heads as well. That’s the engine that they paid a settlement on it. I end up junk it and replacing with a B&S 19 hp. Good luck with it.
