Personal Pace Drive Problem
cruise42
Personal Pace model #20334, s/n 316000000.
By end of last season it felt like I was pulling a ton of bricks and grinding rocks when pulling my rear wheel drive Toro backwards. No amount of traction cable adjustment helped.
Finally found time to take drive completely apart ...everything looks tight. Bearings and bushings, and retainers not wallowed out, transmission shaft runs true. Drive pinion teeth on both sides of mower show signs of teeth jumping in and out of mesh. Sprocket teeth (metal) on both drive wheels look good.
Any idea what's going on ?
I've purchased new bearings, sleeves, retainers, transmission and drive belt.
Don't want to put back together until I know what's going on.
Also...would you recommend using Never Seize on blade driver shaft before reassembling ?
cruise42
Scroll down to your serial number, Service Manual is filled with information.
Any idea how much force is required to untreated HOC bearing retainer from pivot arm ? I put a 1-1/2" socket & breaker bar over wrench flats on retainer and can't get it to budge. Wrench flats are so thin on retainer I guessing corners will round off even though I using 6 point socket.
cruise42
Hey Rivets...any ideas on this ?
Have you removed the external snap ring?
cruise42
Rivets...there is no snap ring.
Model 20334, s/n 316000001
cruise42
My mower was built in 2016...looks like they eliminated snap ring that's show in manual printed in 2013.
