Mike88se
- Oct 11, 2013
- Threads
- 76
- 738
I don't know much about Snapper mowers. I thought they had Hi Vac and mulcher but this one say Hi Vac on one side and Mulcher on the other and has a side/top discharge with a plastic cover.
Snapper model# P217017BV (84956)
The engine is a Briggs Intek 7hp.
Has a bent shaft that barely turns. The deck is good and the transmission. As far as I know everything is good except the block. And the tires are bald. It uses some kind of disc drive self propel.
OEM Parts
OEM Parts
