Parting out a Snapper hi vac mulcher.
Mike88se
I don't know much about Snapper mowers. I thought they had Hi Vac and mulcher but this one say Hi Vac on one side and Mulcher on the other and has a side/top discharge with a plastic cover.
Snapper model# P217017BV (84956)
The engine is a Briggs Intek 7hp.
Has a bent shaft that barely turns. The deck is good and the transmission. As far as I know everything is good except the block. And the tires are bald. It uses some kind of disc drive self propel.
OEM Parts
davbell22602
Why dont ya just replace the crankshaft then sell it for $200? If we where closer Id buy it from ya.
Mike88se
I thought about doing that Dave but I don't think it would be cost effective. I believe a new shaft is about $90 and then there would be gaskets and seals to buy. I've never replaced a crank on a mower but I've done it on a car engine. Not a fun job.
I think I'd end up with more money and timemoney in it than $200.
If it is... or was as good as the Snapper Ninja I have then its a shame to part it. I'm really impressed with the Ninja. I've thought about keeping it.
davbell22602
Then fix it keep it as a backup for your ninja then.
Mike88se
I'm pretty much mowered up. I got the Quick 36, 2 Honda HRB217's, the Ninja, and the exmark 21. I only need one 21. If I think I need a backup and it is a good idea then I'd just pick up a cheap Toro personal pace. I seem to find good deals on those a lot and with the right blade they're decent mowers. Drive down here and I'll make you a really good deal on the hi vac and you can put a new drive shaft in ;)
Mike88se
I'm starting to think more about that. Not to sell but to keep. I think I'd move the bag and the plastic adapter tube from the Ninja and put the plastic block off plate from the hi vac on the ninja. Makes sense right? A hi vac should have a bag... a ninja should have a ninja blade and a block off.
I bet that hi vac would be a great mulcher tho with a ninja blade.
Mike88se
I've sourced a new engine for $99 shipped. I'd need a new blade hub and blade so for $150 total I'd have a good mower. I could probably ebay the fuel tank, muffler, recoil, etc and get $50 of that back. Any opinions would be welcome :)
Sunyimin43
Great!With a blower mulcher to collect weeds and leaves very efficient.
Thomjs1970
It's not to bad but not like the old snappers. if you use gas over a month old it will not run. but for the price it's not to bad just not even close to as heavy duty as the old ones. I use to mow a 1/2 acre that a bit easier.
Mike88se
Thanks for the info guys but it's gone now.
