YTA 20V46
The parking brake pedal will not push down all the way.
When I look inside the engine compartment, I see that there is a lever connected to the rod that is attached to the brake pedal. This lever is hitting the frame and not allowing the pedal to be pushed all the way down.
There is another rod connected to this lever that goes to the rear of the machine.
I'm assuming something is supposed to be moving this rod to allow the lever to move under the frame so the parking brake can be engaged?
