midnite rider
- Nov 25, 2011
- 31
- 1,638
Has anyone tried this oil? Cost about a US dollar for enough for a gallon mix. According to their website:
Opti-2 is a specialized two-cycle, single mix ratio lubricant engineered for use in all two-cycle engines, regardless of brand, model, or mix ratio. Opti-2 is rated ISO-EG-D++, the highest rating available in the stringent International Standards Organization global performance ratings system. Opti-2 meets and exceeds all equipment manufacturers rating requirements. Opti-2 is formulated utilizing patented Eutectic additive technology that provides exclusive performance results:
One gas can covers all two-cycle engines
Highest rated 2-cycle oil in industry
A single mix for all two-cycle engines
Increased performance and longer engine life
Smoke-free operation
Gasohol compatible
Contains "Opti-Mizer" 24 month fuel stabilizer.
Opti-2 delivers all these features while being the most environmentally friendly two-cycle mix oil available. Opti-2's smoke reduction, and gasohol compatibility contribute to cleaner air, while up to 60% less oil is required, which helps conserve a precious non-renewable resource.
Gasohol compatible
