The Cheetah is Scags fastest mower and I have owned it four years. I budget 2 hours to mow my 3 acres and that does not include the needed shower from all the dust.
I find it uncomfortable to run the Cheetah in the high speed trans axle setting. Which means I am mowing at no more than about 11 mph. I find that speed sometimes a little rough riding and quick to steer. [SNIP]
When I was shopping for a mower I talked to a bunch of folks. Nearly all said they wished their mower would go faster. I solved that with buying the Cheetah. The dealer said it was overkill for my 3 acres. I had my mind made up that I wanted speed, the suspension seat and suspension seat platform only offered on the Cheetah. I also wanted the 61 inch deck. I wanted to make the mowing chore quick.
[SNIP] The Cheetah is overkill, too fast, and more expensive than I needed. Everyone was right, but I had my mind made up. Now, I am glad I bought it and would probably do it again. lol
We all have to do what we think feels right for us. That is why Scag makes so many models.
Thanks for the comments mcdonell. I think you hit the nail on the head with the comment "we all have to do what we think feels right for us". I also appreciate you being honest about your Cheetah - you know it's overkill for your job, and you're still happy with it. Nothing wrong with that!
I have both a 1999 Exmark and 1999 Toro that still have almost all the parts made for them. Most Commerical mowers doo unless it was only a few years run on the model.
Good to know. Hopefully Scag will have parts available for the Patriot for a long while. I guess it's technically only been a model for about 5 years but I'm guessing the Freedom Z HD which it evolved from shares a large number of parts. Certainly parts available might be another advantage to the TC II but hopefully that won't be an issue.
A few comments about the Scag Patriot:
Scag did finally listen to their dealer requests and put together a machine with features that only the upper level commercial machines have as standard equipment.
The Patriot was introduced in 2015 and has been upgraded since then. As mower manufacturers usually do a 24 month production run of specific models, as a perspective buyer, do your homework and check the parts manuals for upgrades in models and know what model numbers pertain to which production runs.
As ZTRs with mid mounted mower decks are dusty by nature of their design, it is important to know what type of air filtration system is installed on the engine options that are offered. Kawasaki FX series engines have the Donaldson dual element type air filter system and this is a good thing. The FX series engines also have an engine old cooler and this is also a good thing.
Scag put the Patriot together as an entry level commercial machine with a top level engine. Having a 6.5 gallon single fuel tank is a good thing. The latest model Patriots have an adjustable suspension seat and this is a good thing.
Almost all ZTRs have a rigid suspension which makes them a hard riding machine. Larger tires and suspension seats make the ride more comfortable and the Patriot is an acceptable compromise between lower entry level machines and upper level commercial rated machines such as the Tiger Cat II and Turf Tiger. It is all about the money!
The Patriot has either Hydro-Gear 3400 (61" deck) or 3100 (52" deck) hydrostatic drives with cooling fans, both of these drive systems are very good.
The mower deck although not a Velocity deck, has been upgraded with a larger width deck chute than the original design decks.
Scag does offer two collection systems on the Patriot, a mower deck spindle driven blower model and a mower deck air flow model among other options.
I do limited service on Scags and other makes of tractors/mowers and have had no problems getting parts for older model Scag machines. My local Scag dealer may not have the part in stock but will get the part(s) within a few days, no problem. And having been a power equipment mech and parts man, it is always good to have a great relationship with both!
Thanks for the comments Mad Mackie! I'll check the parts manuals and see what the upgrades are on the Patriot. Do those manuals contain the time periods for the production runs and model numbers that correspond to those runs?
And like you said, it's all about the money. Would I like the full platform suspension, the Velocity deck, the extra speed, the cast iron spindles, the replaceable caster arms, and the tiger eye monitoring of the TC II? Sure I would. Do I want to pay $1500 - $2000 for those? No I don't. I know I'll be happy with the Patriot features for a long long time!
And as you and others have said, a good relationship with your dealer (sales AND parts) is invaluable. That's why I'll be checking out another dealer in a week or two. I want to find the best place to buy based on relationship, not just price.
