Hammermechanicman Lawn Addict Sep 6, 2024 #1 Customer did an oopsie! Then i get this fargon mess. Electric fence plastic string. Has stainless steel wire in it. Just another day...
Hammermechanicman Lawn Addict Sep 6, 2024 #3 Yeah cust asked if i could fix the flywheel. Sorry. Used a hacksaw and a cold chisel to cut the stuff off then found it got up in the bottom bearing. So they get to buy a new spindle.
7394 Lawn Pro Sep 6, 2024 #4 Hard to weld Cast iron, can be done tho,, I bet that wire string did get in the bearing.. Yeoww..
Hammermechanicman Lawn Addict Sep 6, 2024 #5 7394 said: Hard to weld Cast iron, can be done tho,, I bet that wire string did get in the bearing.. Yeoww.. Click to expand... I found the guy a used flywheel on fleabay for $100. Cheaper than wasting time with a maybe fix.
