Oops!
Hammermechanicman
Customer did an oopsie!
Then i get this fargon mess. Electric fence plastic string. Has stainless steel wire in it.
Just another day...
7394
Fresh break on that cast iron flywheel..
That string looks mean..
Hammermechanicman
Yeah cust asked if i could fix the flywheel. Sorry.
Used a hacksaw and a cold chisel to cut the stuff off then found it got up in the bottom bearing. So they get to buy a new spindle.
7394
Hard to weld Cast iron, can be done tho,,
I bet that wire string did get in the bearing.. Yeoww..
Hammermechanicman
I found the guy a used flywheel on fleabay for $100. Cheaper than wasting time with a maybe fix.
