On the FS56 weedeater
mikehouse
Been going thru the love hate relationship with this stick.If you run this hard as in edging,and it gets hot and cuts off,is this normal? I'm thinking i need to adjust the idle speed or the throttle speed.Otherwise it's a very versatile tool.Took it to the shop once,and yea they set the RPM's,but it was worse.I tinkered and got it better.Just asking if i should up the throttle or lower the RPM's,or vice versa.Thoughts?
Fish
No, it is not normal. Adjusting the carb involves fuel/air mixture adjustments along with rpms, and incorrectly doing it can cause piston damage. Here is the pic of a fs56 carb, and its adjustment screws.
