So I just repowered a Craftsman rider with an older 12 hp Briggs that came off of an old mower with no deck. Wiring on the older mower was "inspired" with starter button to bypass starter switch and to kill the motor, the old fuel cutoff valve. No problem, as it seemed to run fine when I got it last year. With all the weird wiring, and as the newer rider had a different wiring harness (several generations between the two), I just bypassed the kill wire (unplugged) , cleaned and serviced the flojet carb, new oil, fuel filter, replaced the gas, checked for fuel flow (including fuel cap) and gave it a go. Here's what happens:
I can start the mower with my hand as a choke (possibly need to replace the choke plate as it is a bit pitted) and it will run for 30 seconds to 2 minutes and then dies. I've removed and recleaned the carb, made sure presets are correct on all the needle valves, made sure float is set correctly and not leaking etc.
When the motor starts to die, I can keep it running for a bit by choking it again with my hand to restrict flow, but then it will die again.
So: It doesn't appear to be electrical, fuel flow seems fine and when it runs long enough to adjust the carb, it runs great...but then it dies again for no apparent reason. It is however hard to start with just the normal choke.
Any thoughts?
Any thoughts?
