old Murray with a 16hp Tecumseh
I have an old Murray lawn tractor that I bought new back in 1994. It has served me well and is no longer my main horse. I still like to use it ever once in a while, but lately, when I first start it up, (and it always starts), it has a very hard "kick" to it. It almost sounds like a rod, but when I rev it up and engage the blades, it runs fine wide open. Can anyone give me a clue as to what it is that I am hearing without hearing it yourself? I sure hate to tear into it, but I will if I have to. Thanks in advance.
carbon build up on the piston?
check the engine mounting bolts at frame. If the blots are loose it will make noise at start up.
Thanks for the reminder. I found that on an older brothers Briggs on a Murray that had broken bolts but had forgotten about it. Does make a strange sound at idle rpm.
