old Murray with a 16hp Tecumseh
royrodgers
I have an old Murray lawn tractor that I bought new back in 1994. It has served me well and is no longer my main horse. I still like to use it ever once in a while, but lately, when I first start it up, (and it always starts), it has a very hard "kick" to it. It almost sounds like a rod, but when I rev it up and engage the blades, it runs fine wide open. Can anyone give me a clue as to what it is that I am hearing without hearing it yourself? I sure hate to tear into it, but I will if I have to. Thanks in advance.
reynoldston
carbon build up on the piston?
royrodgers
What is the best way to deal with that. I know just enough about small engines to get me in to trouble, but thanks to guys like you, I always seem to find my way out.
Pumper54
Get a can of "SeaFoam" and use as directed. That stuff helps clean out a lot of stuff from engines.
Tom
NorthBama
check the engine mounting bolts at frame. If the blots are loose it will make noise at start up.
SeniorCitizen
Thanks for the reminder. I found that on an older brothers Briggs on a Murray that had broken bolts but had forgotten about it. Does make a strange sound at idle rpm.
