clemsonnum1
Sounds like a dirty carb to me. My push mower would crank up to to full rpms and then immediately die so I took the carb off the engine and cleaned every jet or opening thoroughly and replaced all the gaskets. It's working fine now. If you took the nut off the bowl and just cleaned it the gasket could have degraded and clogged the main jet too.
