White Oak Dave
- Mar 13, 2022
- 10
Hello,
I have been working on a Kohler Command Pro CV23S 23 HP twin cylinder in a L130 John Deere. I got the tractor for free because the previous owner blew one of the rods but did not appear to hurt the case or the cam. I replaced the crank, rods, rings, coils and head gaskets. It fired right up but after several minutes it started to stumble under load and blow some blue/white smoke. It now smokes when you start it for several seconds, as if to clear oil that is built up in the cylinder and still stumbles on acceleration. Both spark plugs (new) are wet with oil. I mic-ed the bore and pistons and they are well within tolerance and the end gaps are good on the rings. I also have a 150lbs of compression on both cylinders.
The last thing I have ordered to replace is the seals for the intake valves in the event they are sucking oil in.
Does anyone have another suggestion for the source of the oil in the cylinders before I button this up again and try it? Any advice is appreciated.
Thanks,
Dave
Thanks,
Dave
