OzPete
- Sep 3, 2019
- 3
- 13
Hello all. My first post here.
Fitting three new deck gearboxes to my neighbour's Walker deck. After adding the appropriate amount of 90 gear oil as per the manual, we found the oil is leaking from behind the LOWER bolts that attach the gearboxes to the cast iron connector tubes. That is the 8 screws closest to the top of the deck housing.(see attached pic).
The threaded holes in the gearbox housings are NOT blind holes, they are drilled & tapped all the way thru into the inside of the gearbox.
Can't imagine why Peereless would do that, especially when they clearly configure these versions of their right-angle drive gearboxes just for Walker decks, but there ya go.
So we dismantled, again, cleaned everything up thoroughly, and reassembled with a good quality sealant on the threads of the screws, and put copper washers under the heads of the screws, left it overnight for the sealant to go off, and put the oil back in.
So, cupla weeks later we have definitely slowed the oil leak down, but there is still an oil leak. Slight, but evident, and if left un-checked will eventually empty the oil from the gearboxes.
Any suggestions gentlemen ?
Thanks
Pete
Thanks
Pete
