I managed to pull the flywheel off with a home-made puller using a 2x4. I wouldn't recommend this because the middle bolt did damage a few threads on the shaft, but I was able to file the damaged threads so I can get the nut to go back on.
The breather was very brittle and would not come off without breaking so I have a new breather assembly on order
Parts Diagram - Breather is #7
My other question is:
Before I started I noticed the engine block got VERY hot once it was warmed up. Too hot to touch for more than a split-second. Is this normal?
