Boudreaux In Eunice La.
- Jul 22, 2017
- 2,154
A head gasket will not leak oil , BUT a Valve cover gasket will leak oil and drip under it to the side of the engine block in most cases and then down to the bottom of the engine at the base ....I had the same problem with my kawasaki fx600v on a ferris, not a briggs and straton issue. I thought it was a leaking head gasket but reading above it appears to be a baseplate gasket issue that I havent heard before
