- Nov 29, 2014
- 24,995
And to add to what Chris has said.
The detergents can only hold the tiny solid bits of debris ( usually carbon ) against the force of gravity for so long .
Leave it sitting for a long time & it will form a sludge
On a car engine no problems because the oil pick up is above the floor of the sump
On vertical shaft engines the oil pick up is below the floor so that is where the sludge will accumulate .
No oil will destroy your engine
Oil is not morgage your house expensive .
So buy some & try it .
Make notes on your computer / phone
Next year buy a different one and see how it goes
When all is said & done, it is oil in the most primative engines currently being made
