Oil in fuel pump
madecant
Was wondering if a clogged crankcase breather would cause oil leaking from fuel pump on a 17hp Briggs and Stratton engine, i know people say a head gasket, but it has no other symptoms of a head gasket, and i did remove the head and the gasket had no damage,
Over full sump
Fuel contamination of the sump
Oil too thin
madecant
Over full sump
Oil too thin
the oil was above full level but, i removed oil to mid-way on fill mark (replaced fuel pump after removal and still did it) there is no fuel in oil. as far as oil to thin not sure about that put it doesn't fell to thin.
