mhavanti
If the filter meets or exceeds the "manufacturer's" specifications, it does meet the specs as long as the specs are as stated. Considering the US weights and measures division of each state, the fines are much higher on one filter than the profits for most US filter companies for the year if caught cheating on specifications.
As Doug mentioned earlier in this thread, all his points are a part of meeting and exceeding specifications. Most smaller behind the title companies that contract out to the name brands end up being held to the fire in order to continue receiving contracts by AC, Fram, Purolator, Wix, etc.
Just do your research and buy the one you like the color of as long as it has the by-pass valves, gasket materials because the valve won't bypass if the gasket doesn't hold, etc.
Good luck to you all,
Max
Max
