cruzenmike
- Feb 10, 2017
- Threads
- 59
- 858
Just to point out that you can use the best oil and the best filter and still destroy your engine...it doesn't make it immune to abuse. Constantly trying to jam your mower through tall lush growth traveling too fast and failure to keep the engine free of external debris will likely do more damage than letting your oil change interval slip a bit or using cheap oil and filters.
So true. Most often, the manual will state to check your oil level before every use. If you notice any drastic change in discoloration or anything out of the "ordinary" then you may in fact be due for an oil change. This can happen after 20 hours, or after 100. All depends on how much of a load the engine is under, how well the air filter is working, how many starts were cold and so on...
