Oil changes
X-man
How often do you guys change the oil in your equipment?
I try to change it in my lawn tractor about once per month, I put 15 hours on it per week. I just changed the oil in everything today.
I change mine every Saturday.
And my filter once a month. I was using a WIX. Now I use K&N
(( racing is the only sport that you need two balls ))
I change my filter every time. I use a Purolator.
Every 40 hours. JD filter, synthetic 10w 30 Mobile One in everything, except the older ones. 30 wt synthetic in them.
Yep, that's what I use. Used to use Pennzoil, switched to Mobil 1 Full Syth. 10W-30. Guy down the road kept preaching to me about how Pennzoil is bad, so I finally switched.
i use SAE 30 only with a touch of Lucas and change the filter every 2 months if it needs it or not
I change mine every 50 hrs and I use cheap o aftermarket oil and air filters
Once a mowing season, at the end of the season, which for me is probably about 50 hrs. of operation. Amsoil Small Engine oil, and a new filter if applicable.
