Oil changes
X-man
How often do you guys change the oil in your equipment?
I try to change it in my lawn tractor about once per month, I put 15 hours on it per week. I just changed the oil in everything today.
I change mine every Saturday.
And my filter once a month. I was using a WIX. Now I use K&N
(( racing is the only sport that you need two balls ))
Every 40 hours. JD filter, synthetic 10w 30 Mobile One in everything, except the older ones. 30 wt synthetic in them.
Yep, that's what I use. Used to use Pennzoil, switched to Mobil 1 Full Syth. 10W-30. Guy down the road kept preaching to me about how Pennzoil is bad, so I finally switched.
i use SAE 30 only with a touch of Lucas and change the filter every 2 months if it needs it or not
Once a mowing season, at the end of the season, which for me is probably about 50 hrs. of operation. Amsoil Small Engine oil, and a new filter if applicable.
