cpurvis
Synthetic motor oil is superior to conventional oil and there is no debate about that from anyone familiar with them both. Synthetic oil offers superior viscosity, wear protection, and fluidity over a range of temperatures, with reduced contaminants. Royal Purple is a good synthetic oil - superior to conventional - but I believe there are better choices. Consider instead Mobil 1, Pennzoil Platinum, or Quaker State Ultimate Durability. Just make certain it's full synthetic, not a blend.
The price differential can be minimal to non-existent. I recently purchased 5 quarts of Pennzoil Ultra Platinum at Walmart for $25. Pennzoil offered a $10 rebate so I only paid $15 or $3 per quart.
Having said all that, use conventional oil during break-in.
Ok...but just how much better viscosity, wear protection, and fluidity over a range of temperatures, with reduced contaminants will you get with synthetic oil? I have yet to meet the person who was mourning the loss of his engine due to oil-related failure because they didn't use synthetic. I've also never seen any quantification of the benefits, such as, "you can expect your engine to last 2,000 hours if you use conventional oil but you can expect 2,500 hours if you use synthetic" especially in something like a lawnmower engine.
If any independent lab has done comparable test-to-failure testing, synthetic vs conventional, I'd like to see it. The oil manufacturers will tout a "benefit" even if it's only .01% and not be lying...they're just not saying how how much, if any, benefit there will be to the end user in the real world.
It's one thing to say that using a particular product gives "peace of mind" but if you're going to say it's "superior" to another product in this way or that, there has to be some data, somewhere, to back that up. And that data needs to come from independent testing or the field, not the manufacturer's marketing department.
