I have a Scag Freedom Z with B&S engine....for the life of me I cannot find what the engine oil capacity is and the type. Any help? and oil filter size?
You've got three identical posts on this. You don't need to flood the forum with posts on the same question.
It's also just as easy for you to do the internet search for an answer as it is for someone else.
SAE 30 would be a good choice. I run Royal Purple full synthetic. I don't know the amount needed, but I'd guess 2-3 quarts with filter. Add some and check it, add more check it again. Fire it up to fill up the filter, then top it off.
Once you know the level, right it on the wall or something, then next time there is less checking.:smile:
Yep,
When it come to motor oils the most important thing is how long it has been in there.
Everything else runs a poor second.
A cheap oil changed regularly is a lot better then an expensive oil left in for too long.
Ideally mower oil should be changed at the end of every season.
We run Walmart Super Tech 10W30. Been running it for several years. No problems. We have three Tiger Cats with Kawasaki 22 hp engines. Try to change them at 50 hours but some times it goes a good bit longer. We always change oil and filter at the same time.
I have one that has 1700+ hours on it. One that is in the 1000 hour range and one that is around 750 hours. If it will deliver that for under the conditions we run them then I don't believe anybody on this forum runs em any harder than we do cutting Pensacola Bahia grass in the Southern heat of South Alabama.
