There are two things to consider when it comes to oil, first is if it doesn't have an oil filter or pump, then you need to run a non-detergent oil.
Most automotive oils are multi-weight. (5W-20, 10W-30, etc)
most non-detergent oils are straight weight oils. (20W, 30W and so on)
In an engine with no means to filter out wear particles, carbon, and dirt, you want that junk to settle out of the oil and not be carried through the engine with the oil. Detergent oils are designed to carry that dirt and debris to the filter where its trapped and removed.
Viscosity is important, too thin when its hot out and it can't protect the engine, too thick when its cold and its like molasses when its cold and the motor won't turn over.
10W30 is fine in most small engines but since most older motors don't have a filter or oil pump, (they rely on splash lubrication), the detergent factor is where the problem lies. Especially on a new motor that's still breaking in.
One problem I find these days is that there are no goo quality single grade non detergent oils, most are low grade mineral oil at best.
Some aviation oil is single weight non detergent but its pricey and hard to find in lighter weights if you can find it at all. There just aren't that many motors running it these days. Especially the large WW11 era radials that it was most common in.
The choices tend to be to run a good 10w-30 and change it more often or run the low grade base mineral oil in 30w.
I find that the cheaper 30w oils tend to burn easier, the engines run hotter and the oil doesn't last long at all.
None of the local parts stores carry straight weight oil here anymore, the only places I've found it is at the dollar store or at small engine shops.
