Seems like keeping oil within a reasonable range (auto gurus panic at 280F) is like keeping the fins clear . Two "fluids" working to transport heat away. I am sure the thermal engineers have tried every scheme imaginable by now. Picking up an Intek 24 head and feeling the light weight and small size should impress us the things work at all with cool intake mix just inches away from hot combustion and exhaust gas temp. With my Intek 24 in hot weather I have always seen the heat increase quickly during HARD work, like mowing uphill with grass catcher. Is this the poor crank and rods passing heat to the rest of the engine and the pistons undersides "feeling" the heat and adding it to combustion heat and into the head? If so one would think any cooling of the sump oil would have a beneficial effect on the whole engine.
On the other hand "casual" work in the same heat like hauling a little utility trailer hardly moves the needle. Perhaps those who do not experience 300F simply use their ?riders gently? As a consumer the so called "warranties" included with the new big box equipment are practically worthless. Why not just go ahead and create ads like we see on TV for expensive drugs like..."ask your doctor if xxx is right for you...and remember you may have thoughts of suicide , but you will feel much better..." A JOKE, A JOKE,A JOKE.
Ken , thanks for the tip on the inspection plates on the heads. I will look for them.
