You can look for a manual online. You'll need to check that your mic is calibrated correctly.How can I insure I am reading it right and it is accurate?
And YouTube usually comes to the rescue to teach us stuff.
This appears to be correct. That's a good tip to unscrew it to the 1.000 mark, which is easy to identify. Then when you seat it again on the object you're measuring if it moves about half a thousandth, it is about 0.9995. Since I got spoiled by digital micrometers a long time ago, I use this crutch a lot to make sure I don't misread an analog mic (or a digital one with a dead battery). Back it off to the next full .025" mark and then count the thousandths that go by when you close it again.I see $9.0 + .75 + .24 + .004 or .006 ($9.994 or $9.996) depending on the photo. A full revolution is .025" and it is almost that. 4 turns on that one is .1" If one wants to work it backwards, unscrewing it .0004 would make it 1.000" which is barely showing as the 4th hack mark. 1.000" minus .0004 would be .9996". Another way is that is about 1/2 a hatch mark on the barrel from a full1.000" inch. If it was screwed in to the first hatch mark it would be .001" less than 1.000" or .999". Since it is about 1/2 a hatch mark it is about .9995". The fine division is a 4 or a 6 depending on the actual angle the viewer looks at. The photos are not all that good which does not help.
It is almost to 1 in I think you are very close 999 and 6/10. There should be a master in the box you need to zero it in so you read 1.0000 loosen the thumb drive to adjust then tightenHow can I insure I am reading it right and it is accurate?
this is reading .375 , or 3/8"You can look for a manual online. You'll need to check that your mic is calibrated correctly.
