GearHead36
- Apr 26, 2023
- Threads
- 23
- 334
I have a Kohler Command 17HP (CV490S, spec # 27515) with a Walbro carb that leaks. I found a video from Taryl where he provides the Kohler carb rebuild kit p/n (20 521 04-S), and it's $48. Cheap, made-in-China carbs run around $20 on that jungle site. You guys have any luck with the cheap Walbro clones? Do you have any you'd recommend?
Also, the wire to the fuel shutoff solenoid broke off when I disconnected the bullet connector, so I would need a new solenoid, too. The cheap carb option, which includes the solenoid, is sounding good.
Or should I bite the bullet, and get the OEM rebuild kit?
