LawnWizard
- Nov 17, 2021
- 106
I have a starting issue that I have not encountered before. 2013 Hustler Fastrak Super Duty. Kawasaki FX691V-CS18-R. Ran perfectly, shut it off, now nothing but the carb solenoid click with key turned to start position. Battery 12.65. All safety switches verified. 12.6V at the starter and 12.5V at the trigger wire with key in start position WHEN DISCONNECTED but almost nothing when trigger wire is connected to the starter. Tried a new starter thinking it is shorted. Same result. Engine will start with trigger wire removed and jumping its post to POS at the starter. I'm confused b/c if it is the starter (both) bad then I wouldn't think it would start by jumping the solenoid. Also, why 12.5V disconnected but nothing when connected to the sol?
I have tried new ignition switch and double checked all safety switches. PTO works with engine running. Gives the normal clunk noise if turning key to start with PTO on.
Thanks for any suggestions and help.
Hugh
Hugh
