LawnWizard
- Nov 17, 2021
- 106
Well, believe it or not I did exactly that. Unfortunately, in this case that mower uses 3 relays, the 2 I swapped were both starter relays. Star Tech referred to them as "Starter relay 1 and Starter relay 2". So apparently, if either is bad the starter motor does not engage.Remember, one simple way to check relays is to label them, then swap them temporarily to test the equipment.
I know now.
