Not sure I understand carbs well enough!!
Sorry I just came in from the darn cooold a little bit ago and was waanting to huuug the heater. We went from the 70s to the low 30s with snow showers. Shivering all over. Boy weight lost is not fun.
yes you do need a different air cleaner base and gasket. The PNs posted are for the kits that comers the gasket.
I wonder if I got the correct gasket I could modift the housing to meet the need? Does anyone know the part number for the gasket?
Thanks so much!! I just ordered one. Should be here by the weekend. Without the correct filter housing to copy, do you know if the notch is just angled to go into the main air inlet or does it do something trickier? I was thinking that I could drill/cut a slot on an angle towards the throat. Seeing that it ran fine without the filter housing I am assuming that it should work that way. Any thoughts?
Thanks again for your input!!!
If the image is correct and my memory but its been a long time since the last repair that use one of these; it should just be angled into the main passage.
Hey Everyone,
So, here is the final report. Star Tech was right that the filter housing needed to be modified. The strange thing is, Even with the modification the carb still did not run great. I purchased a replacement carb from the jungle site and that carb runs perfect with the housing installed. The splitter is back up and running and the old cark is in a box for parts.
Thanks so much Star Tech for helping me out here.
The replacemnt carb I purchased can be found here...https://www.amazon.com/dp/B0DQTLRVWG?ref=ppx_yo2ov_dt_b_fed_asin_title. I hope that link works...
Hello L.,
Thanks for the resolution to this problem. Most of the time we are left hanging and people forget to follow through with a solution and closure.
